A Qucik Question
SamHolmes
If you're running front freewheel, it'll almost definitely be a 127.5mm spindle length. I'd imagine it'd be 68mm shell width, but if you buy a 73mm shell width BB, you can always either use a thin spacer to sort it out? Or just take your BB out and measure the shell (if you can't get an accurate measurement with your cranks/bashguard and gubbins all in place)?
