T-rex
Tom Booth
I bought a t-rex frame over the weekend and when i got it i asked for a new set of rear brake bolts *kid walks into back gets me 4 brake bolts, the actual ones* hands them me, and when i get home buildign the bike up and put the bolts in the back brake and there too long to go to the bottom of the mounts! Anybody else had this problem???
Also is it ok if i chop about 5mm off these bolts to make them fit, as im using spacers and cant get the proper tension on the plates needed to hold the brake
Cheers
Tom
Yea i Had to cut mine down as well, i think!
Might have only been the top/bottom???
Should be fine, but just make sure you dont crossthread the mounts thats the last thing you want!! My mate did after 10mins of having his new steel megamo.
cheers lads, im going to have a crack at it tomorow, im not scared to cut the bolt, im scared of nakering me frame, going to elvo on saturday and wont be able to get the money to have it helicoiled if it nakers!
Cheers
Tom
If you have doubts - try the cut-down bolt in a loose nut first.
That way if the cut is a bit 'off' - at the worst it will only have cost you a nut & bolt, and not any kind of engineering on your frame.
If you cut it straight, and just tidy the thread up a little bit with a file, you'll be fine.
... err, fine that that is - as long as you've not been given titanium bolts of course, which would have already cross-threaded by the time you've got home. (Y)"
use the little circles from the inside of kmc kool chains, they're perfect!
johal
That's an awsome idea (Y)
I ws gonna say space it out rather than cut the bolts down, but meh, you've got it sorted (Plus it probably looks better) :blink:
