Painting On Fabric
Mr Motivator
Depends wheter you are just going to paint them and wear them once off (because then you can just use any paint) but if you are planning on wearing them and they need to be washed then you will need fabric paint. You can also use a texta called a Laundrey Marker and those are like a permanent marker but they will stay on no matter how many times you wash the T-shirt. If you go to a craft shop there will be a range of differnt fabric paints and you may even be lucky enough to find a spray on one. There is also this special liquid (I'm not sure what it's called but you'd find it with the fabric paints in a craft shop) that makes other paints that you mix it into stay on your clothes when you wash them.
iv tryed looking for fabric paint and i found it.. but its either in a pen form or little crytals.. which i think used for tie dye..
but your best bet is.. make a stencil.. get some spray paint.. car paint.. graffiti.. what ever LOL or get some water based paint imultion or something and again make a stencil and get a spunge and dab it on .. iv done it with a few of my impulse Tee's (Y)
