Disc Rotors
moose-iow
Get 2 pieces of wood. Put the rotor between the blocks of wood then put it in a vice and tighten the vice. :P
are u sure that works?
surely the rotor would just spring back to how it was.
i would do it with a wide anjustable spanner which has been degreased/cleaned to avoid contamination.
ta
If it was left in there for a few hours/overnight then I don't see why not.
You need to deform the rotor plastically - by forcing it past its elastic limit. Time won't do this. And clamping it flat won't produce enough force.
Dont use your hands - it will put oil on the rotor.
Get a clean adjustable spanner and do it like that.
words of a wise man :D :P
cheers dude :P
