Magura Boosters.
wayneone
Are the original magura 2 bolt boosters compatable with 4 bold mounts? i know they will just go over the top 2 bolts but will they bolt down(let me go into a little more detail) The slot on the righthand side will be cramped down by the bolt, but will the hole on the left be cramped down or will it just fit over the bolt head? is it possible to cramp it down but just using a large washer or just using the edge of the hole?
Also as there not too stiff and will only cover 2 bolts i was thinking of using 2 butted up together but separated with a 1mm washer to prevent rubbing, Do you think this is a good idea? im going to compare weights/prices of boosters currently on the market aswell to see if its worth while.
It depends what you ride realy 'caus i was going to get one of them for my t bird but the bike shop people said that it wouldn't fit my back tyre (so i decided to treat myself to a carbon fibre one, courtesy of onza) it would fit th 4 bolt mountings, but you gotta think about how far away your stoppers are from eachother.
Im not sure but i think the magura boosters arent very good anyway :P so it may be better to buy a new booster :)
You could get the:
RB booster
Echo Team booster
Onza Carbon fibre booster
You can get them from tartybikes :$
Cheers
Mitch :lol:
