Another Problem With Hope Disc Brake
chrishayton
Right, the left hand pad (piston) on my mono trial doesnt move much at all, i bought it 2nd hand and it was sticking, so i sent it hop and recieved a new caliper and still have the same problem.
so does anyone else suffer with this. its the left hand piston, the right 1 moves fine. cheers
Not really to sure about hopes. but try putting your finger over the right piston and hold it down, then pull the lever for a few minutes and this should make the other piston work harder and may stop it sticking. :'( ;)
As i say im not really to sure about hopes though. :'(
Worth a try though.
DOM
have had this problem so many times, and so have many others i know. I sent it back to hope after it did it like 3 times and they sent me it back about a month ago with new seals and it did it again. i have found that pumping the pistons out quite far then squirting gt85 around it then pushing it back in then doing it again works. also found that gt85 works better than dot fluid for it.
mine does it when it gets really wet, like when i go on a real wet ride. same for anyone else?
It is sooo weird because I have had my one a year now, and I have never had this problem. I have just left it alone and it has worked its self out. It did rub a little after I had set it up, but just left it and it worked its self out and doesnt rub.
just tried this with gt85 and seems to be working, cheers :lol:
ye gt85 is a good dofer.
i used dot 4 on mine and it worked, but its a pain in the arse the best thing to do would be to (if mechaniccaly minded and can bleed a hope brake) get both pistons completly out of the caliper, may need the flower style tool to do so, and have someone lube them up good and proper as if half of a piston is dry and half not it can penetrate to the dry bit, so its best all lubed up before sticking them back in.
Waynio.........................
silicone stuff or a smearing of copper slip.
  • 3 months later...
Thought i would add my brake problem to this topic.
Ive had a hope mono trial on the front for around a month and its been fine till last night.
I was out on a ride and for 2 hours it was fine, was gapping to front wheel and going up to front quite happily.
Then all of a sudden as i landed on the front wheel it locked hard, screamed like a pig and almost launched me over the fornt. Now, its does this everytime, screams, judders and has lost all modulation.
Any help, all i can think of is a stuck piston????
