What Crank And Bash For A Mod
tom tom
what crankand bash could you use on a mod if you were not using a ffw?and what are the wheel sizes on a mod is it 19" or 20"??
tom tom
you should get tensile uci cranks and your wheels are the rear is 19" and the front is 20". the rear is smaller so you can fit big tyres.
,,,,,steve
Yeah you've gotta make sure you get the right cranks for the BB otherwise it won't fit.
The tensile uci cranks( here ) are very good quality crankset but they're not cheap, where as the Raceface Crankset is cheaper, but you sacrafice quality for price, but you can get the Raceface crankset in square taper, but it doesn't come with a bash ring.
i suggest you look around:
supercycles
ChainReaction
TartyBikes
Hope this helps! Good luck and i hope you make the right choice (Y)(Y)
Mike!!!
I would say use the new echo cranks (or old) with the echo bashring.
OR
The Zoo Cranks with the bashring.
The new echos and Zoo cranks both come in isis BB so i suggest the FSA Platinum ISIS from CRC
But if you purchased the 05 Echo Cranks you can get either ISIS or Square taper. But i think the ISIS Tapered cranks would be a better option (Y)
Cheers
Mitch
