Some Help,
Gaz M
Just bought a 6 pin to 4 pin firewire cable, and nowere on my pc has the slot for it ive looked everywhere and all my pc has is loads of USB ports, my pc says this is this a firewire card or whatever and if it is why hasnt my pc got any slots for it if its not what is it IPB Image
You checked the front and rear of your case? Not any opening or closing areas on the case which they might be conceleaed behind?
If you still can't find it, try taking of the side of your case, and see'ing if the firewire is internal only. I can't see that happening, but it might be.
What is a 1394 network connection?
A. New Windows XP users might notice a new network device labeled 1394 Connection on their system. This network device is actually your FireWire card. Although most users use FireWire to connect video and storage peripherals, Microsoft chose to list FireWire as a network device, which might confuse some users. Either you can ignore this connection, or you can disable it by right-clicking the connection from within Network Connections (from the Start menu, go to Settings, Network Connections) and selecting Disable.
Ner. :P
