Eno Question No.302 : Stripping
poopipe
ok, im sat here in the garden thinking i should cleanse my eno.
ive taken the lockring and the funny round springy washer thing off but nothing else seems to want to be removed.
how the hell do i get to the pawls to degrease them ?
im not gonna bother if i have to take the whole thing off the crank cos i dont have the tools here..
You don't have to remove the snap ring. It just holds the bearing in place.
After you have unsrewed the lockring, just pull off the outer ring (to the side where the lockring is).
The you can clean pawls, springs and the ratchet.
dammit - i was hoping to get back and edit the original post before anyone laughed at me....
i took the blue rubbery ring out and flushed it with gt85 a couple of times. now it spins better and sounds like a chainsaw again.
thanks for not insulting me though :)
will this work on acs claws too?
i have the gold/black one from select bikes that is welded or something, will that unscrew? :ermm:
steve.
not unless you're really strong (because its welded shut)
its only an ACS, if it stops working just buy another one
Edited by poopipe
is your freewheel skipping?
if you're taking an acs apart...get some ice-cream tubs and take your time....get all the bearings back in with MINIMAL grease...and some wkd40 on ze pawls/springs..
and remember to put it all back the right way up...that is frustrating...
otherwise...don't bother...it's only a bmx ?
adam
i wouldnt service an acs personally, just not worth the efforet, unless you're really really broke. they are a complete whore to service. i took the lock ring off mine to give it a propper flush out with GT85 and lost 4 or 5 bearings :(
Edited by mat hudson
