Brakes
Adrian
if you really want to spend money then :
xtr vee calipers >link<
heatsink vee converters > link<
avid ultimate lever >link<
nokon cables >link<
xtr carbon fibre booster >link<
plazmatic v-fly pads >link<
thats pretty much my dream set up :shifty: but if moneys an issue then a maggie with plazmatic crm pads will do fine :lol:
Defiantly go for a HS33. They are easy to maintain and bleed once you get the hang of them. I got my new one recently from chain reaction cycles about a week ago, It's a 2004 raceline yellow magie of course :P , But they only come with evo mounts, I tried to explain to the guy that i wanted 4 bolt mounts but I couldn't understand a word he said. Anyway, i'm running my HS33 (bled with water) with A light grind, Zoo! pads and it locks amazingly well, I can do a gap and land more backward than vertical and it still holds.
Here is a direct link to the HS33 in CRC anyway maggies.
Edited by Jaffacakes
:ermm: water bleeds are quite common
i use it, as do the majority of all my mates who ride.
Works awesome, especially if you bleed it in the bath, no chance of air getting in to the system.
Agreed ^^^^ I also use Water, It feels much nicer and it doesn't give you that spongy feel on the lever.(Y) Its also cheaper to top up on. :)
Cheers Phil
