Hope Mono Trials
weebryan
I have had my mono trials for a year now and i have to keep cleaning the pistons and removing the pads on a regular basis as i pull the lever nothing happens then it clicks then all a sudden they totaly lock u, is there anything a can do to prevent this? i think it is a build up off brake dust that jams the piston, not sure.
Just a sugestion as i dont ride with a disk but.......... Maybe you need to have a re-bleed. Is there anything on youre disk because that dose'nt help. If you have a know from riding with matt that putting water on your disk helps get rid of all brake dust so that makes them sharper. (Y)
I haved tried washing them with water and still the same, my mates does the exact same must be a common fault. They work fine after i have have cleaned the back ofthe pads and sprayed the pistons with conntact cleaner and then move the pistons in and out but only last for a short while
