Stripped Threads In One My Brake Mounts
Ollie Histon
On some frames it is possible to put a longerbolt with a nut on the other
end, i have done this in the past but only you will know from looking at it. (Y)
Yeah I'ev done the same (Y) saved me a few quid
I suggest you try the longer bolt first, If that doesn't work
Helicoil it. Basically you tap to M6, then insert a steel insert which brings the sizing back down to M5, If that doesn't work
You'll have an M6 thread in your frame, buy an M6 bolt and use that (Y)
