Onza Crank
_skj0lsvik_
Every person that has a t pro basically has these cranks.
most people that buy the t pros leave things to screw up like freewheels and cranks.
The proof is in new memebers where a t pro topic comes up once a week about broken parts on there bikes.
Sooner or later ull want a eno or profile/king but the acs on the mucsleman will do your for a couple months if u read the lock ring topics under frequantley asked questions.
you just have to have them done up very tightly and you're all good to go!
yes if you like to destroy the taper on the cranks, i would suggest maybe checking the torque settings for the cranks, i believe its 60Nm although manufacturers reccomendations may vary.
theres nothing wrong with most onza cranks, i used a set of armstrongs (on 26") and didnt have any problems in the time i used them.
Edited by hardcore_raver
Yeah, I`m gonna use it on a 26" so its good that you didnt have any problems with that... The ACS freewheel is ok for a little while isnt it?
But is it possible to use a bashring on it?
Thanks again, Schyoelsveek
make sure you check length dude. also, dont follow manufactorors torque settings, put all your force into tightening untill you cant turn anymore.
"mat" accepts no responsability for you shearing your bolts.
