Tpro To Aorta : Changing Frame - Need A Little Help From You Kinda Peo
CBProductions
Ok Im going to be getting my aorta soon,
I would like to know how long the steerer has to be? Or how long the headtube is with headset cups fitted !
As I was silly and cut my echo easy forks down to the t-pro's length with no stackers involved.
Im not too sure if the easy forks will fit although I do have the old original tpro forks which did have two-three spacers on when fitted.
Second Issue is that the aorta doesn't have a bashplate and I currently don't run a bashring/freewheel protector, I use monty cranks with an eno and haven't really any idea what to do ?
Thats all cheers folks , if you could be so kind to help a man in need of throwing his frame together!
Craig
for the bashring, you must get a bb about 127.5 mm wide not any smaller and then its just a case of putting it together.
sorry cant help with steerer tube.
or you could also just ride with cranks and no bashring but try to land everything backwheel.
Edited by Synergy
I think I have a try all one which is adjustable between the two sizes ? .
Thanks for the advice , if I could land everything to backwheel it would be a godsend :P
lol tell me about it.
i went from a t-master to a gu so i had to buy a new bb so also bought echo cranks, echo bashring and an eno.
so i was in same situation but daniel ko from viz/trials-uk helped me out with it all. (Y)
