Help......................
Phill_Monks
right.....my right crank arm is compleatly f**ked and i need to get it off but the bolt has rounded off :(>_<
ant it is REALLY tight on :(
have any of you got any sugestions how to get it off no matter what.....even if it means grinding the crank in half :D
Cheers Phil
Edited by GU_TYPHOON
Araldite a hex/allen key in there? heard someone on the forum suggest that before, never tried it but sounds like it might work.
Yea its been done before get the strongest strength glue you can get your hands on
and an old 8mm you dont mind loosing - glue the allen onto the bolt cap
get a bit of leverage i.e. 6 foot barge pole
jobs a goodun'
Try a star tap,(for people who don't know what it is, its a stay shaped bit which u tap into the bolt, then you put like a handel onto the bit and unscrew it) i did on my crank bolts not that long ago.
