Crank Coming Loose
lnl-trials
hey i had this problem.. try extracting the crank and clean it all up, make sure it isnt too warn.. then grease the bottom bracket up ( for maintenance as you dont wana keep taking the crank on and off ) then put some Loctite around the bolt and tighten it up as much as you can... that solved my problem.. otherwise it might be the bottom bracket is too warn and it will make the arms become loose no matter what..
hope i helped (Y)
Bret just make sure the bolt has a decne tallen head in there not rounded off along with the allen key, it will be harder to remove thats all and i don;t want you having a dud bolt in there first hand.
If you can tap the crack on with a rubber or nylon mallet then torque it up tight with the bolt, leave over night
