My Pads Keep Coming Undone
monty boi
Check the wee tabs on the backing are ok where you press it onto the slave, if any are missing/munched that's your problem.
You can buy new backings for like 20p or sumthin off rimjam.com last time I checked.
There about half a cm away from the rim
Adam.
Maybe try undoing the tpa more and setting them closer to the rim. (Y)
...by which i mean actually undo the mounts and move them physicly closer to the rim.
Edited by JT!
Dont tell us you use tar?????
Cause if you do, your pads will be sticking to the rim, and just pulling themselves off of the clips...
nope i dont use tar ;)
Adam. (Y)
Put a penny in between your rim and pad , undo the bolts and push the pads in so it touches the penny
then tighten it all up.Get the penny out and your brake is set up perfectley .Do it on both sides (Y)
Nice one there working ok now (Y)
Thanks
Adam. (Y)
Edited by monty boi
