Cleaning A Hub
Chris Elson
Right, i'll presume you know how to crack that little hoare apart.
If not, it's on the Hope website and plastered all over this forum with a search (Y)
Once it's apart, lay all the pawls and springs on a bit of cloth and make sure they're safe.
With WD40/GT85 in hand, blast all the shite from the pawls/springs/ratchet ring.
Clean them up with the cloth and use a degreaser to clean them all up shiny if you like.
Then get some chain lube (Tri-Flow or similar) and squirt a little onto the ratchet ring and spread around.
You can use a small dollop of grease on either end of the 3 springs to help them seat to the pawl/ratchet body correctly.
Reassemble and you're done.
