Tv Out Playing Up Grrrrr
JTM
My Tv out has always worked fine (once i got it working in the first place!)
I dot know whats happened but now when i go to play something on tv or clone my desktop/extend it etc, the screen just flickers. Somethings defo happening as it flickers and jumps a little when you try to play a file on tv. Its connected via a S-video/S-video cable with a s-video/phono adapter at the tv end. The phono input on the tv defo works.
Any ideas??? I dont know why its stopped working
It might just be that you're running the wrong settings somehow - If the resolution or refresh rate is too high the TV will struggle. Try fiddling with that. It's also worth checking that all the cables are in place and secure - The ones I use are a bit dodgy and one slight nudge will lose the picture. Other than that I'm not sure - Can you try plugging it in via S-video? I guess probably not...
