Welding Pashley Forks?
bob87
Hi, I'm considering changing to front disk on my bike.
The only problem is that there are no disk mounts on any Pashley forks.
The forks i have had 4 Magura mounts for a 24" put on.
And this got me wondering, is it possible to have a disk mount put onto the forks.
I like the way the front end of the bike sits and don't particularly want to change.
So is this possible?
Thanks. BOB
Bigman did a set of forks for me which worked fine. Clive Leeson does mine now which are equally good.
Rich
Cool, thanks very much.
Iolo pm'd me and said he could do it aswell, so i've got a couple of people to choose from.
Thanks
Just an idea but what about getting it done to the opposite side you side hope too. I've thought about it and I think having it on the drive side on the front should make any difference. Just flip the disc and put the caliper on the other side.
If you ran disk on other side you would need to run the caliper on the front of the forks. The mounts on the forks would snap, as you'b be pulling the caliper off the forks most of the time instead of pushng it into the forks.
