Chain Ring It's Bent Badly
Fixed Pants™
(N) on the bike i got yesterday, 2nd hand, the chain ring has bent from where it wasnt secure, its badly bent, if you need pics i most proably can get them, but does this mean i have to buy a new chain ring? i can probably straighten it out abit, but the real problem is i can't get the crank arm off so i can get to it and straighten it out, any help on how to get the crank arm off would be much appreciated as it might save the day (Y)
OK, ill take them as soon as i can, but what about getting the crank arm off so i can get to it to straighten it, i think it will be straightenable (my new made up word?) :P
You need a crank puller tool to get the crank arm off, your LBS will have one if you don't. Stick the chain ring in a vice and try straighten it out and see how long it lasts.
Edited by bhups
mate if its bent lots theres no point in bending it back..is it steel or aliminium chainring? bend aliminium back and it will most probably snap...either way whatever it is it will be weakend when you bend it back.id say its advisable to get a new chain ring rarther than bending that back when you can get a new one that is strong , as strait as it can be and isnt going to put your safety at risk.
as for the crank...why cant you remove it?
are the threads in the crank stripped so you cant use a cant extracter?
if that is the case then your best option would be to hit it off from the inside with a block of wood and a hammer.if you dont have a crank extracter and want to get the crank off its probably a good idea to purchase one.they dont cost much and you would be able to get one from your local bikeshop or something like halfords.
max...
As its only my second day riding trials i can't do to much so its not gonna have too much pressure on it, thin gis, it looks really thin, doesn't look like it should/ will stand up to the pressures of trials
I'm just about to go to Halfords so they can try to get it off.
Not sure why i can't get the crank arm off, it just doesn't seem to be moving when i try to lever it off.
Edited by 49ccminicrossah
mate dont let them rip you off.if they get it off dont let them charge you like a tenner.they will put a tool it it and do it up..it will come off in seconds...if they ask 4 a tenner tell them no cos thats called ripping you off like halfords always try to do..buy a crank puller there too so you dont have to take the bike there every time you need to get your cranks off
you wont be able to remove the crank by hand because its on a taper.thats what holds it on tight.look at the shape of the bit that the crank is on when it comes off (Y)
max...
Edited by max-t
max...
will do, i think 'halfords professional (cheap shit) crank extractors are 9 quid, so ill probably get one
all depends what make they are..take a tenner just incase they ask for a stupid price...usually cheeper in your local bike shop but halfords will have some or one...i dunno how much halfords charge for one cos i dont go there for my stuff :-
max...
