Problem With Bb
Fvil
I just notice that my chain moves in and out(towards the wheel) when i spin the cranks
could this be the Axel is a little bent :ermm:
or
the Taper is worn down :S
or
my crank is loose (N)
Help me every one
thanks a million
EDIT: it basically wobbles in the Freewheel area!!! which causes the chain to move in n out
Edited by ffdevil
my freewheels is pretty New
It might be the bearings bedding in?
If your axel was bent your crank would wobble.
Just tighten up your bb, freewheel and your cranks and if it still wobbles it will be the freewheel bearings. (Y)
EDIT:Also check the square taper for damage.
Edited by _CRED_
