Bottom Bracket 4 Front Freewheel
beezerdude
I pretty sure you dont, you just need the right length (i.e. shell x length) And the shell length is going to be either 68 or 73mm . To run a front freewheel you just need some cranks with thread on them, not like middleburns, like the new adamant,zoo,czar,gu,etc cranks.
do you need a certain type of bottom bracket to run a front freewheel
you will need a bottom bracket with a long axel,
if your looking to spend more than 50pounds on a freewheel buy and skf bb and a tryall freewheel.
On my SKF i just use a front tensile sprocket
mike
