Arm Puller
T-OM
I ripped the thread out of my Onza Muscleman crank when i was trying to fit a freewheel a few weeks ago, i ended up having to take it to a bike shop and had to pay 15 quid to get it put on. i don't want to have that problem again so i was thinking that i would buy an arm puller so that i can get my crank arm off when ever i want so basically i want to no what size i should get and where i can get it (websites). (Y)
Thats a universal puller, i.e non bike specific. The link posted earlier is specifically for bikes, which would be better ideally as they're smaller and easier to use in my opinion.
You mentioned stripping the threads in your crank though, if it's the female thread in the same hole as where you bolt the crank on, then the bike specific pullers wont work obviously, and yes you'll need one similar to the one you found.
But, it'll only be able to remove the drive side crank, and you'll have to get one that fits your bashring (assuming you have one) snugly so as it doesn't bend/get damaged.
Hope this helps,
Alun
Bleh! All this kerfuffel when you could just pop down to th'Halfords and get a bikehut one for 8/9 quid, work fine and you only need an adjustable jo anna (spanner). Problem sorted. Oh and any size will do as long as you haven't got a really obscure crank and BB.
Edited by Fat Pants
Yeah just get a park tool crank puller. But if your skint use a rubber mallet.
this is for all future posts, i can't use a crank puller as i have ripped the thread out of both crank arms using one.
Edited by T-OM
