Can I Repair My Rims ?
kid creole
Hi i have two separate rims that have both split at the seam where the rim is joined together , has this happened to you ?
can you rejoin it ?
how do they join rims in the first place ? cant see a weld.
will onza give me half price crash replacement for this even thou I've grinded the rims ?
Can probably be repaired as an interesting project , but not in a way that they'll ever be trustworthy for riding duties again . As for half price replacement , I suspect that only applies to frames , and doesn't extend to componentry sorry . Must have had pretty poor spoke tension to allow the rim to separate itself .
rims are usually spot welded or pinned
take them to a company that works will aluminium, take it to your local industrial estate and see what you can find.
i had one repaired before which had split at the join, it cost me 3 pound to have it welded and re pinned and i still have it in my shed as a spare 3 years on
see what you can find localy
Edited by maxxis26
Depending on how far the seam has ripped it is still ride-able. I was unsure on this but tartybikes assured me it was fine and built the wheel up. I think your best bet would be to loosen up all the spokes and true the wheel from the start. It should be fine then.
But what Maxxis26 did was cool. 3 quid, can't go wrong there really.
Yeah i am still riding one of the rims and was going to have the other one built up soon but then noticed the split which was pretty annoying as it exactly the same as the other one.
i might get my mate to try welding them up again or maybe just get a new rim.
thanks for the advice (Y)
make sure it done by a pro you dont want it falling a part mid ride
