Monty 219 Alp
db-t20
The t-pro is better equipped but the spec is tbc. Which makes it an uncertain decision over which bike.
The Monty looks the part though especially in Scothbrite. With vee mounts some may say it 'makes it worse' but vee brakes still rule. As you have Hs33's already then you could fit them to the t-pro i guess or with some evo mounts to the Monty. But why waste those loverly mounts on such a brake?
As you have guessed i like the Monty. Yes it needs some upgrades but it still wins for me.
if im about to spend nearly £ 400, i want to spend it wisely :S
Don't worry which ever bike you buy i'm sure it will break just after you get it. Happens to all of us.
The point being, have you looked into second hand bikes?
A 221pr for £300? As an example. I know you can't post. But can't you pm?
