Front Disc
Parr22czar
ello there mate same problem i have on my cable it s**t..there should be a alen key screw on one side of the pads let that out a bit maybe take it part give the parts a tad spray..just a little of wd 40 ...dont let it on you pads or disc wat ever you do ok ...give it ago ...thats my edvice anyway dude cheers bennyb w.b (Y)
Urm, yeah, listen to this guy and your brake wont work!
Hope brakes use a self adjusting system as it's an open unit.
You can't really adjust the pads to how close they are to the rotor, they do it themselves.
Take you wheel off and then carefully push the pistons apart witha clean screwdiver (you can take the pads out but leave them in). Now do not pull the lever as you'll pop the pistons out of the calliper.
Now loosen off the bolts holding the calliper to the forks. Put the wheel back on the bike (making sure it's in the dropouts properely).
Look directly along the rotor so that you can see the pads and their position to the rotor. You want the pads to be parallel to the rotor and you want them to have same amount of space either side of the rotor. This can be made easier by holding your hand or a piece of paper behind the calliper. (if you can't get it even, you may need to place or remove spacers between the caliper and the forks to adjust it's position)
This may take a few attempts, but carefully tighten up te bolts again, trying not to move the caliper.
Now pump the lever a few times to move the pads back out and aslong as you've set it up straight, it will self adjust so that it doesn't rub.
PS. You don't need to bleed the brake for this or adjust oil levels.
And you don't need to take it apart to oil it, as you'll destroy the seals.
Hope this helps,
Rob
Edited by Tall_Rob
