Wheel Swap
tom jersey
Hi, the best places to try them out is on curbs or pipes on the floor or something low so that if you fall off you cant damage anything.
To practice try just doing front hops on level ground then front hop and while your back end it still in the air try leaning back and hop on your back wheel.
Then when your 'OK' at doing them try just doing front hops on level ground then front hop and while your back end it still in the air try leaning back and hop on your back wheel but try
and push your back end down and forward and pull your front end forward and up like a see-saw action, resulting in a wheel swap.
Hope I've helped, jack.
learn to wheel swap......just do an endo and find your balance point. When you start coming down away from your balance point, release your front brake and let the bike roll through your legs and pull the bars upwards (if you dont let the bike roll through your legs, your back wheel will miss the obstacle). Try to keep your body over where you want your back wheel to land and push you bck wheel to that spot. As usual this technique will differ with obstacles of different heights and types. Hope this helps?
I'm no good at describing how to do things so i won't even try, But my advice is to practice as much as possble and you will soon be able to do them, maybe try to do them on a curb for a start (Y)
Check out http://www.trashzen.com/ for tips
ok cheers for the link
hopefully i will master it soon (Y)
thanks jack i'll try it soon cheers (Y)
