Profile Hub Problem!
gr8grumble
hello all, i used the search and no luck!
right.... the driver on my profile hub is wobbly... when my wheel is on the wheel does not wobble, its only the driver on the hub.
does this mean i need new bearing? or does anyone know how to take a profile apart?? if soo is it easily done without everything breaking?
normally i would keep riding it untill it doesnt ride anymore but... its making my chain go really tight.
does anyone have this problem and can someone please help.
thanks in advance...
graham
I trust you've taken off the lock ring and stuff?
There is no need to take off the lock ring. Get a screw driver and put it behind the cog and lever it off, aslong as you dont let the driver go flying off no pawls will fall out. Then check the bearing and if neccesary replace. If you wont totake the axel out aswell it comes out the same side as the driver and just give it a firm whack on the non driver side and it will pop out.
