Onza Fall Guy, Or Echo Lite?
Mod Man Leo
Echo Lite's are nice forks and by the title of them you know they are a weight saving componant, The Fall Guys are heavy but indestructable. They are made of 4130 Cro-mo but the trick bit of the Fall Guys is that forks are usually heat treated (heated up to intense tempreture and then cooled rapidly to make the fork stronger) and then the legs are welded to the steerer tube. But with Fall Guys they are put through the whole treatment again after welding which makes the whole fork heat treated! Making the weld points stronger.
Have you seen the Zona Zedd's on Tarty?
