Echo Reds, Dengura, Water Bleed.
SCOTTY___
Right, bought a dengura and i asked for echo red's to come with it.
Now, ive got them on a smooth rim with tar atm, there OK without tar and good with, but they wear tar off fast and its annoying and it seems im applying it every 5-10mins...
so, ive looked on select, tarty and Trials-uK also looked in the Pad-review thread ( no luck ).. select, tarty and Trials-uk recomment a light but sharp grind...
so has anybody tryed it? how was the wear life?
also whats the best angle / cutting, grinding disc to use for this type of grind?
thanks in advance,
x
Abdab runs that set up but without the Dengura. His brake is a beast.
According to beau. The Dengura's lack alot of power and dont match up to the standards of a Magura.
I could be wrong but try a Magura with that set up and it will be beasty.
Echo reds and grind = NO.
Danny.
Danny.
I know he does, abdab is using a different rim to me aswell, so differnt braking surface :) also abdabs brake is simular to exact preformence as mine..
and dont listen to beau, hes an idiot :)
best pads for a grind which you actually want to last are harder pads, try plazmatic CRM's or even zoo pads.
Personally a grind is a grind, just make sure you grind round the opposite way the wheel rotates (so you get a more aggresive grip)
You do know ZOO! pads are even softer than echo reds?
Ive got some Coust pads if the echos die anyways, could always buy some new one's. anybody tryed it?
x
Yeah I have tried echo red pads on a water bleed as I am currently running one. They are good and as I said above if you want them to last more than 1 ride I reccomend a slightly dead grind, a fresh grind will rip these pads apart.
Glad I bought a second pair at the bikeshow from tarty's for £10.
