White Rim Tape?where From Or What Can I Use?
hugh_b
Yeah as said use some sparky tape. You can get it in all types of colours. I have a range of colours that we use at work, if you want some id happily send some to you if you give me your address but you can prob get most colours at halfords/B&Q or something. When I did my wheels i just went round the rim after I had laced it and used it so the smooth non sticky side is going through the holes in the rim, if you go round a couple of times it wil then stick to itself rather than your rim and you wont get all kinds of bits or crap and grit stuck to it like you would if you used the sticky side pointing out through the holes.
