Hope Pro 2 Hub Maintenance
padarik
when i was tryin to swap my rear cog over i was pulling so hard on the cog that it just pulled off so you could see inside the hub, my advive would be put your wheel in a vice (where the cassette would go) and pull up or down what ever
hope this helps
Why would anyone ever put a hope hub in a vice to pull the freehub off? they should just pull off with fingers
im just thinkin of a easy way to do it, sorry
but yea you can just pull it and it should just come out
Its often a good idea to twist it in an anti clockwise direction while pulling it so the pawls dont rip the seal as you pull them out. At least you did with XC/mono/bulb hubs, having not opend my pro2 i wouldn't know for sure.... can't hurt to do it anyway though.
