24seven Holroyd Riders Help
dan_welshriders
i guys i have a 24sevenholroyd frame with a czar hub, my hub was supplied with snail cams but i dont know how to fit them. is there a screw or something that is ment to be used with the cams? the hub has allen key bolts and the frame has horizontal dropouts, every time i put pressure onto the peddals, the back wheel get pulled into the dropout. ive just switched from normal dropout so i dont know what is going on.
any help would be great
danny
Snail cams need something to push against, normally a bolt in the dropout (look at pics of most monty dropouts, probably the easiest way to see it)
However, to run cams you'd need to drill a small hole into the dropouts, tap it, and find a suitable bolt, as I don't think the 24seven frames come with it.
A set of BMX style chain tugs would do the trick though, if you'd prefer, and only cost about a fiver or so
hey cheers mate, yea i thaught so. i think its more hassle having to drill my frame, so i think chain tugs are the best idea. if anyone has used both chain tugs and snail cams, which is better to use? is it worth the hassle to fit snail cams?
if chain tugs are in order, which are the best for hard trials use?
cheers
Edited by dan_welshriders
