Base Ta26
Tommy d
Just looking at my options at the moment and thinking the TA26 would be a cheap frame around the length I like, should I need one.
The main thing I need to know is about strength. I've heard they may not be the strongest frames on the planet.
I also want to know where it is that they break (if they do). So far 4 out of my 4 trials frames to date have all gone in the same place, on the chainstay just behind the BB. Do Bases ever crack/snap here? If they do, there might not be much point in me buying one!
Thanks
Gonna have to leap to Base's defence here , and agree with Pauloliver ( as usual ) in this being well priced for what you get . I believe the first generation were prone to failure at the seatstay / seattube weld , but only if ridden without a saddle . The newer versions as depicted on Tartybikes seem to be redesigned , with an ovalised toptube replacing what was an octagonal toptube like mine ( 2005 ) has .
My first one developed a fracture at this junction , and was promptly replaced by Bikedock , by the one I've now been riding for well over 2 years . At this price you can't go wrong , just discard the supplied bashplate , and you're left with a reasonably light bike that's obedient on the back wheel and spins well . Mine ( link in sig ) only needed a spray 'cause of some scratching . Get one , let us know how you get on .
Cheers for the advice guys, hopefully I'm not going to need one if I can get my current frame repaired (steel) but it's good to know.
Just out of interest do you know much about the warranty? Would it be invalidated if I took off the bash plate? Is it one year?
Thanks
Nope , no problem there unless you somehow damage the bottom bracket shell . As for a video of one being ridden ...I intend to finally
get some footage of my soopa doopa awesome trials style goin' down . So yeah , some sloppy uninspired hopping will be released soon .
Sweet, on all counts!
I was lucky enough to ride for Base many moons ago, and I found them one of the most enjoyable ride's I've ever had! (Apart from Spode!).
For the money you pay, you get a well built frame that's great for starting out on, strong light and flickable, suitable for street and natural. In 2 years, I went through 2, and I loved every minute of them.
Darren
