Bottom Bracket!
Reece26
crank puller also from tarty's ask them when u order you bb tool
There's alot of play bottom braket i think my bearings are shot! do u no what bottom bracket would fit on my echo control! is it 122.5mm axle or 127.5mm? becaue im about to order from tartybikes! along with my crank puller and my bb tool! :D
Edited by Reece26
Hey if you need to tighten your bottom bracket up ASAP then just get a flat headed screwdriver and use it like a bottom bracket tool put it in and turn it worked for me but it doesn't last very long i used mine for ride an had to re tighten but i done real tight so that should do you until you get your tools but you are best of using the correct tools as other wise you have more chance of breaking something i think you may just need to tighten your bottom bracket and not shot but i may be wrong good luck
billy
billy
Thanks for that! :D But do you no if i can do it without taking my cranks off? because i need a crank puller for that :(
Hello again and umm im not sure...im at my dads and haven't got a bike here so don't know sorry you mite be able to if the screwdriver is small enough to get past the crank arms or if u get a piece of wood and hammer and tap the bottom of crank arm it mite come of im not sure. i just use a screw driver if not got the tool an hit the bottom of the crank arm but it does damage it (paint chips and small dents) but works. good luck
billy
