A Few Rear Disc Problems
JT!
I'm fitting a 07 200mm Hope mono trial on the back of a Ciguena. I'm using an +somthing adaptor. I have a couple of problems...
1. The disc mount is very fat, only 4 twists of the bolts come through, will that be enough, or will it strip something?
2. The adaptor does fit, but only at the bottom of the disc mount, is that going to be a problem?
Also, any tips on setting up a rear disc with a forever moving rear wheel?
Ta people!!!
Ta people!!!
1. buy longer bolts? (or use shorter steel ones ;) )
buy a 74 kingz for tention?
The ones i have seem to be steel, and the adaport is a strong material, not like the shitty plastic avid ones.
74 kingz for tension? :S
You seem to be an intelligent boy so I'm sure you can figure out why the wheel is moving? :P
You've got to sort that out, a disc will never work well if the caliper isn't PERFECTLY aligned with the rotor.
I don't get on with chain tuggs, lol.
