Fu*k! Again!
JT!
Oh deary me, your really not having the best of luck with these adaptors ate you !
Did you buy it new? if so i suppose you could send it back and exchange it for a different one.
OR you could grind that little bit off the adaptor so it sits properly?
Cant you just run it with a 160 brake?
Mike.
I supose i could run a smaller disc like i do on the front. But i really want the keep it as it is.
The fitting of the 200mm rotor was intentional. :) (That was in responce to a reply that isn't here anymore :huh: )
Edited by JT!
who makes plastic adapters?
ultimate weight saving..
Avid.
Stick to maggie! :P
I now no that I dont want another monty dual dics,
These are only inital problems. And the only reason i made them in the first place is becuase i've never had double disc befor. I wouldn't let if put you off.
