What A Polava
El Cristoff
Right, All my theads have gone in my magura mounts. one side has been drilled and tapped to M6, on side still remains M5.
Shall i drill out the M5 to M6 and buy a M6 helicoil kit, i mean, would that work?
Also the M6 side has no thread in it, so will the M6 tap work on these?
Sorry if this is a repost, couldnt find any information on what i needed.
while ago i read a decent idea...
cold weld/araldite some studding into the mount and then hold the clamps on with a nut (Y)
Ahhh this is genius... mainly because its what I had :) take a look:
you had to run booster spacers otherwise the nuts would you wouldn't be able to tighten the nuts up otherwise the sides of the mounts would stop you turning it. but otherwise a clever idea in my opinion.
Edited by NileBrown
What have you actually done there?
Edited by stevenjenkins.klb.
