Need Advice
sholiver 11
It depends on what you've got in them, care to tell us? standard oil? water?
Should be perfectly fine.. just let it warm up again on its own and dont sqeeze it/ bend the hoses around if its properly frozen.
Edited by Skoze
mine froze when i was riding :S but it was when i left it for like 2 minuits this was at night though wen it is colder so it will probs be ok......but bleeding it with oil wouldnt be a bad idea in winter loads of the people i ride with had the same problem
I know this isnt an answer to the question but why the hell do people have water in their brakes instead of oil and how do they stay lubricated without oil.
Becasue in a magura the seals are plastic so they dont acually need lube in them , but if you were to bleed a hope with water it would just ruin the brake because the seals are metal.
  • 1 month later...
