Strange Hub Skipping
Phil H
It's a hope mono Ti, was riding today and it not so much skipped but jerked a few times.
It wasn't when I was actually applying alot of pressure, it just happened randomly for example when I applied some pressure to slow riding fakie for a run up.
I've got enough tension, my chain ring is brand new and my sprocket shouldn't be too worn, does anyone know what this may be?
Phil
broken spring, pawl or worn rachet. pop the freehub off and see yourself
Springs should be all good, replaced them recently. Pawls shouldn't break I wouldn't think. If its the ratchet gone I'll cry
I'll have a look at it later on
Phil
Basher
another hub gone then?
Better not be! You sold it to me! :P
AND I just got it re-built with an 07 echo rim.
Phil
have you checked your chain for a broken plate or anything?
i had a similar problem today couldnt work out what it was for ages then saw one of the plates had snapped causing the chain to jerk
chain didnt snap though haha and i was riding normal (quite harsh)
just a thought mate
My mono did the same, turned out I had a snapped axel :P
lmao, i thought id nakered mine today bad, before the jerk/skip thing i put the wheel on and it completely locked up like a fixed hub, no movement at all
took the thing apart and realised id put the spacer in the wrong place haha
Right, cheers for the input guys.
Took the freehub off, checked the ratchet was good which it was, cleaned the pawls, stretched out the springs.
Rode for about an hour and it happened twice which wasn't too bad but still kind of annoying. The confusing thing is it didn't actually happen whilst riding trials, jsut when I was riding on the flat :S
Phil
Phil
i snapped my axle riding to a chip shop.
too much lube? or not enough? Don't use grease use a thing layer of XC chain lube. that kind of hub sould be serviced like ever 4-5 months I did with mine, By service I mean a clean and a relube.
Ah cheers dude this is helpful.
Sounds like a stupid question but how would I actually clean the inside, can't get cloth in there and would squirting it with water not do some damage?
Also what do you mean by XC chain lube, WD40? any Penetrating oil?
Cheers, Phil
