Need A Little Help
Dave Anscombe
Yeh so you have to drill to m6 then put the insert in wich will make it back to m5 :) and therefore alot stronger better threads
Indeed sir!! :P there you go Dave :) (when you get a helicoil kit it comes with the correct tap size i would use that just to be shure) (Y)
I know this sounds silly to all you people who know about tapping and all that stuff, but, couldn't you drill it to m5 then put an m4 helicoil in ?. That would save you going raking through your shed for more bolts. wouldn't it ?
McInnes.
Bolts have a m5 thread on them so if you put a m4 helicoil in you would acctully need to find smaller bolts(I think). :P
