What Are Rock Pad Greens Like?
Headley
they're mint on a smooth rim with a nice sound, andd on a grind they have a lot more lock with little sound. But altogether there a good alround pad which gave me aload of confidence to go bigger...
what is hold and bite like, do they slip often?
Edited by Headley
The hold is incredible in the dry on a smooth rim, but in the wet my brake has slipped but not often.. On a grind they're awesome in wet and dry but they'res a lack in sound, The bite feels awesome too, mainly in the dry on smooth and the sound is sweet. But the bites is also mint on a grind in wet and dry but I run my pads on smooth and I prefer them that way..
If you wanna ask anything else add moi msn lilsmithy_2008@hotmail.co.uk
Oli
  • 3 weeks later...
  • 2 weeks later...
I had my set and they were shit, Worst pads ever.
had them set up fine and gave thema good 2 weeks to bed in.
Still nothing.
So I got a ubber light grind and they were even worse.
:huh:
there mint pads on smooth, but one a light grind pretty crap, Rock blues are mint in a grind
Mine were ok (on a really light grind).
Didn't work in the wet though, but in the dry were awesome.... for 2 weeks. Then they wore down in 3 days.
Theres better pads around. Such as the Heatsink range, Koxx range and plazmatic crm's.
My personal favourite are the Koxx browns :) they last years, always loud and bitey with immense hold and work well in dry and wet.
I'd suggest using them if you want a good brake in most conditions.
If you don't ride in wet and want smooth rim, the Neco red pads are meant to be amazing on smooth
Still nothing.
Exactly what happened to me
They were crap on my smooth rim
Have they changed the compound in recent months maybe?
'Cause all they ever did with me was slip!
I'd recomment Plazmatics!
They're EPIC!
what do you mean when you say on a grind ?. Is it a trick or something ?
thanks bill
Edited by billy_deacon:)
thanks bill
A LOT of trials riders take an angle grinder to their rim, gently running it around the surface
to "roughen up" the surface of the rim's sidewall to enhance braking performance,
With the right pads, a Grind can be awesome,
but with the wrong pads, they'll just ware down very quickly!
xD
But for the best summer brake, keep a "smooth"(unground) rim with soft compound pads!
:D:D
Ben
Edited by Benjaminge
