Echo Cnc Hydrolioc Brake
nicks
Hi, all i was wondering if the echo hydrolioc brakes were any good. Ive been told the pads they come with arnt any good so can someone please recomend some pads to go with them.
Thanks
Andrew :)
the pads are fine...if you water bleed them however, they have what i like to refer to as the colindar effect...they just dont hold bleeds at all...the seals in the lever are tripe, just get an 04 magura...
I agree the pads are fine but if you want different pads you should specify if you have a grind or not.
For example I like the blue rock trials pads for the rear because I have a grind, but I use the green for the front because I don't have a grind on the front.
I like the rock pads, but I would probably go with the Heat Sinks next if I wasn't switching to VEE's
Do not get the CNC backed ones though they are known to rip the knob off the brakes
see the quote below from Echo's website
"Note: Never use aluminum backing brake pads for ECHO rim brake system, because the alunimun backing will cut the knob of the cylinder very easy. In such a case, warranty will be null and void."
  • 4 weeks later...
People always seem to think that their crap because they leak....
They only leak (in my experience) when they have been bled with water.
So they leak when you use the wrong fluid in the brake, that doesn't make them shit at all.
It's like saying a Shimano disc brake (that uses mineral oil) is crap because if you bleed it with dot fluid it kills the seals and leaks.
Echo brakes aren't designed to have water in the system, so why use water?
Edited by boiiing
But, IMO, it's pointless buying a product(Dengura) that is very expensive and that isn't any better/is worse than a cheaper product(Magura)
A cnc'd lever body is going to be far stronger than the magura bodies you can buy now ;)
So it's stronger..... - good point
Leaks when bled with wrong fluid - not exactly a bad point as it's the users fault.
expensive - I've snapped 2 magura lever bodies, snapped prongs off 3 cylinders. Doubt it would have happened on a Dengura. So the price isn't that bad.
Slave cylinders are smaller so crank clearance is better - good point
Edited by boiiing
But you don't have a Dengura,
So stop arguing with me!
LOL
I can see what you mean about the wrong fluid and all that but there aren't a lot of people out there who brek maggies like you do!
xD
I have used a dengura lever blade and body.
And there are a lot of people who break the magura bodies......
Edited by boiiing
LOL
xD
Think before you speak
many people have broke maggies. Its coman for lever bodies to snap, cylinder prongs to break hoseing to break all the time, tpas breaking although dengs is worse and many more stuff i cant think of.
Still would have a maggie over one though
Neither were maguras though were they? They say you can have cooking oil in as long as its flushed out,But not water... You hear far more cases of a leaking deng brake than maggies.
just goes to show that maggies are in fact better :P
Edited by NileBrown
That shows maggies can be bled with wrong fluids.
I never said maggies weren't better, I was just saying that people say dengura's are shit because they bleed them with the wrong fluid.
I've had 4 echo brakes. 2 of them leaked (non water bleed!), lines break easily, slow rebound, spongy, the brake pads are gay, I honestly have nothing good to say about them.
I'd rather just have a magura with aftermarket lever.
Edited by Jason222
