Is It Possible?
RossMcd
would it be possible to change this hub from a 116 spaced hub to a 135 spaced hub by changing the axles? And would it work on a stock?
help would be appreciated
It could be done (possibly without even changing the axle-just run a load of washers/spacers) but you wouldn't really want to.
1) A singlespeed 135 hub has much wider flange spacing resulting in a far stronger wheel build than that hub would give.
2) Those hubs have unsealed cup and cone bearings.
3) It'd more than likely result in a really poor chainline.
You'd be much better getting something like this... or any of the Echo/Gu/Adamant ones which are reduced to £45.
