Gu Le 08
gu trials
How much do you think i could get for this as a full bike:
gu le 08 frame
echo lite forks (disk only)
echo headset
try all rims rear king and front echo hub
rear maggy with cnc coust pads
monty eagleclaw tyres
echo tough bars
front avid leaver with haze calliper and gothic rotor
gu cranks
echo external bb
team stem
token lock-on grips
gu booster
if i have missed anything let me no and ill tell you what it is.
thanks
Edited by gu trials
GU LE 08 frame - £280.00
echo lite forks (disk only) - £70.00
echo headset - £42.50
Try-All/ Rear BMX Chris King Hub- £325(Hub)/£39(Rim)/£10(Spokes)/£10(Build) - £384.00
Try-All/ Front Echo Disc - £55(Hub)/£35(Rim)/£10(Spokes)/£10(Build) - £110
Rear Magura HS33 - £65.00
HeatSink CNC Coust Pads - £32.00
Monty Rear Eagle Claw - £23.00
Echo Flat "Tough" Bars - £30.00
Front Avid BB7 180mm - £44.50
Avid FR5 Lever - £7.00
VIZ Front Gothic Rotor - £30
GU CNC Cranks - £105.00
Echo External BB (Discontinued) Truvativ GigaPipe - £35.00
Echo Team Stem: £35.00
Token Lock On - £12.00
GU booster - £25.00
Total: £1330.00
(Based On Truvativ Giga Pipe BB/ Avid Front Brake System)
Hope this gives you a rough idea (Y)
Thanks,
Dan@Trials-UK
£750ish if its all in decent condition.
I think he means he wants to buy that spec. If your going to be that specific about your spec then you'll have to buy most of it new-ish. But keep a look on fs, as full builds are usually total bargins at like 500-600quid for a spec similar to what you posted
No mate i have it all already but i seem to be getting worse and not riding a lot and i just woundered how much i would get for it.
thanks
