What Chain Is The Best For Trials
Reditus
What chain is the best for trials because i am getting fed-up with my snapping chain.
I snapped my chain today and it was a koolchain
I also found that the koolchain can be a little heavy as i am trying to keep the weight down
thanks
Red
thanks
Red
It has to be a KMC cool chain.
Mine never snaped, It lasted ages, I had to et a new one beaseu it got to old and I had no more drop out for it to pull into tension it had streched so much.
All in all it is a great chain.
Has my Vote.
Has my Vote.
Thought the first thing was that was going to be said. i use the koolchain on my dirtbike and my trials bike but unluckely i managed to snapp it :-( , ok, i will go for the koolchain
thanks
Red
How Tight or loose was yur chain?
I run the chain tight enough not to rattle but loose enough so it bends esily when pushed by hand so it is the right tension - i think i am just unlucky
Red
i used to snap loads of chain but i havent recntly as i have been careful when putting them together,plus i oil regular too.i founds khe kollapse cains to be good ,but i stopped using them once i got tensioner issues.
steve
I do lubricate my chain a little so each link moves smoothly. i work in the workshop in a bikeshop so i have my hands on all lubricants so i know that is not the problem.
Edited by Reditus
Red
Do you make sure you have the chain joined proply when you join it?
Could be a weak link.
Hope I helped.
Hope I helped.
Yeh, the link was connected properly because i am always carefull when working on the chain. i think i just has a faulty link, thats all
I have been running the same chain on my dirtbike for 2years with no probs, now i am using it on my trials bike for a while till i get a new chain
anyways, i am going to bed now as it has gone midnight here so thanks for he help everyone and goodnight
Red :rolleyes:
Red :rolleyes:
Hmm, You just must be unlucky then.
thanks
Red
KMC 810 or 710.
Also learn to use your body ( right preload on gaps for examlpe ) to do the tricks, because it's a great pressure on chain when you use only a pedal.
