Magura Julie, Avid Bb7 Or Magura Rim Brake?
petar@sbcycles
id go with the maggie,but thats cus i like rim brakes.. juicys offer good power and have good modulation. bb7's have huge adapters that give a lot of leverage on the fork legs which cause your forks to crack but are really powerful and maggies are loud and with that setup will be really bitey and will probably hold best
Thought bout a front vee ;)
but ill vote for a bb7...
At first sorry about my english :( hope you can understand me..
Now i`m with vee but use tar... this is shitty for front brake.. haven`t here choice of good vee pads...
I have front magura now with koxx brown and now i`m waiting my new frame and new fork, probably zoo fork.... and can`t decide what to be for 4 bolts or disk...
I`m for rim brakes at all and like vees too but how i said- haven`t any choice of pads for it.... Now i`m only worried for the 4 bolt mounts... Most people say that they cracked them, but they used front magura with tar... no one ride with grind.
Can someone, who ride really often and use front magura with grind, say on how times you make new grind and do you crack forks?
yeah they do.. compare hopes to bb7's
Hope: http://www.chainreactioncycles.com/Models.aspx?ModelID=15622
Avid: http://www.chainreactioncycles.com/Models.aspx?ModelID=13721
Stop posting shit. The only reason Avid adapters would be bigger would be if you were using a bigger disc. I trust you wouldn't be stupid enough to compare one for a small rotor on a Hope to a big Avid one?
EDIT: Wait, do you mean caliper? Even so I don't really know what difference that would make to snapping your forks. The only reason people break forks with BB7s is because they're so grabby and powerful that you can do stupid things (E.g. drop-gaps to front wheel) with them causing your forks lots of stress.
