Where Can I Get A Star Nut For Urban Forks?
Jarl
So, I pulled the aluminium bit out of my star fangled nut just now. Doh. Also, they're urban forks, which apparently have an 18.3mm inside diameter (i measured 18mm with a crappy ruler, so it seems close enough) because of a very thick aluminium steerer, so standard star nuts are out. There's another star nut slightly lower down from a previous failed attempt, so headlocks are out. Tarty have their small sized star nut for £3, but it's currently on order and I suspect it'd be too big anyway. I don't have a dremel/grinder to grind down a new star nut.
Suggestions????
Edited by Jarl
get a long metal stick and hammer and smack the other star nut down and out of the bottom of the steerer
can use a headlock then
nu uh. You can see where the steerer gets narrower, there's a kind of lip, which the old star nut is currently sitting on (sideways :turned:). Needle nose pliers won't shift it, either >_<
Pity really, because I like the idea of a headlock system.
Edited by Jarl
Hit it harder, they fall apart eventually.
you need to smack it really hard...
use a sledge hammer to smack it
