Echo Rims (26)
mad max
I have just got my Heatsink yellows through the post from the advice from pad reviews, and about to grind my rim.
I have ground other rims in the past,but they was no where near as expensive as this back wheel. i don't want to fook it up :(
I know what to do but is there any specific advice you could give me related to theses rims and pads for optimum performance.
I will then be out for a few hours to test the difference from tar.
Sorry to rush but i will be doing it about 1.00pm today, wish me luck.
Thanks.
Did you buy one of them £50 SL rims? I got myself one of them, quality pretty turd to be fair, good old Echo. :closedeyes:
Use a brand new cutting disc and just try and get a clean even sharp light grind. You should be able to get a nice grind without killing the rim to hard, even with the anodise.
No its a 2007 rim. Just finished it now. Set my Maggie up spot on with Penny's and just tested it in the house, sounds fooking great. :D
Off out now for a few hours to bed it in. I will give some results later.
I still get a bit nervous grinding rims.
I personally much prefur to have smooth rim set ups, that way the rim lasts a hell of a longer and aslong as your setup is decent it'll work just as good (i mean smooth rim specific pads).
Like my Atomz pads on a smooth try-all rim was outstanding! So much better than my CRM's on a light/medium grind ;)
Holy Sh*t these have to be the loudest pads ever. When i got to my riding spot i new there was something wrong because when i put power down on a pedal stroke (any side) the pads were touching the rim.
I did a little fine tuning and fook me, i thought my rear brake was going to rip out of my frame. It has made me realize that i am dragging the brake when i don't need to.
I just thought about touching my lever and it screamed like a fooking crack whore on a de-tox. I have learned more today than i have in weeks.
I cant believe i went back to tar.
Thanks for the replies.
Good to hear. But your going to have to keep re-grinding it every few weeks for the same performance. That's why grinds suck. Not against them just that's the honest downfall of them.
Yeah man, i do agree.
I was running Koxx browns last year on a v-hard grind and they just worn the grind off (pads was made of kryptonite)
Sorry for the old superman reference.
But i need some feeling in my back brake,Tar is so on and off. I have been running good old Maggie's basic blacks with tar because i didn't want to grind my rim, new bike and all. But it is time to get all natural and it hasn't been sunbathing weather all year in my part of town.
